Old 11-09-17, 03:50 PM   #1
Garak
Garak's Avatar
Default Welding Cast Iron
I was hoping that this broken cast iron corn grinder leg could be welded.
The other three legs are OK and even with the break the grinder seems quite stable. I know it could never be as strong as it was before the break.
What do the welding experts here think? or would it be easier to plate it up from behind and secure with some bolts?
Here is the problem:
Lister D 18DH 1936
X-Factor, where the bewildered are wheeled out to be sniggered at by multi-millionaires.
Garak is offline   Reply With Quote
Old 11-09-17, 04:30 PM   #2
slatteybarn
Plate and bolt would be my choice,it's what would have happened in its working life unless the farm would have been lucky enough to have a blacksmith.
Use coachbolts and square nuts and a bit of angleiron dipped in brick acid to age them,but wash it off afterwards and dont have anyother bare metal around while the lid's of the brick acid.
Phil
Old 11-09-17, 04:56 PM   #3
I like welding, but as I'm just about to try welding cast iron for the first time i'm not the one to ask for advice.
Considering the placement of the three domed bolts already there I'd be inclined to add a piece of angle iron from behind and a 4th bolt, spent some time making sure the angle is shaped to fit accurately with the cast section will make sure the repair is stable.
Wolseley WD 8, Stuart Turner P5, Maytag 92, Kubota KND3, Maytag 72, Lister D Spec 11.
Old 11-09-17, 05:14 PM   #4
It can be welded and it can be as strong as new, but it's a specialized job and not cheap. I have used a company called Cast Iron Welding from Corby. The item is heated to 500C then welded with new cast and peened as it cools.
I'm afraid that for this job it's unlikely that you would justify the cost - plate and bolt it!
Old 11-09-17, 05:58 PM   #5
There you go Martin, concencus seems to be do a 'farmyard repair' like I suggested when you phoned earlier! Looks an ideal spot for a bolt and plate job and wont look out of place at all. Now go ahead and get it bought!!
Old 11-09-17, 06:21 PM   #6
Dazzla
Dazzla's Avatar
It's not going to be the highest quality cast iron, so get a nice bit of weathered plate and use that with some old bolts. It'll add character.
Dazzla
Old 11-09-17, 07:09 PM   #7
Garak
Garak's Avatar
Thanks to all who replied, all with sensible advice.
A bolted repair it is then.
Thanks
Martyn
Lister D 18DH 1936
Old 11-09-17, 10:20 PM   #8
Thanks
Martyn
Once bolted securely together, if the crack bothers you filling with weld should be easy enough, even mig welded with normal steel wire will do the job.
Old 12-09-17, 09:06 AM   #9
I welded a root cutter frame using nickle rods no pre heating, should be ok but plate reinforcment behind wouldnt go amiss on a leg.
Old 12-09-17, 11:16 AM   #10
cameltank
cameltank's Avatar
No real expense needed just to weld - using plenty of pre heat - its a time consuming job more than expensive - I've successfully repaired cracked spokes on old trolley wheels before and a similar leg issue for a B.E.N compressor - all using my oxy acetylene set.
However have a read of the following link which explains it in better technical detail and advice - and if you don't have the kit then a good character building farm repair will do nicely too!
http://www.lincolnelectric.com/en-us...on-detail.aspx
Welding cast iron is a great skill to have under your belt - practice on some scrap if you have it (or buy some old broken cast iron kit of fleabay for a couple of quid - old stoves worked for me and a broken one can cost as little as the .99p starting price...
best
Hamish
cameltank is online now   Reply With Quote
