Old 22-11-16, 05:39 PM   #31
Find and report all of the casting no on all visible parts, it can have a general idea from that, im working away from home until friday, I will look then.
Old 24-11-16, 07:59 PM   #32
Garak
Garak's Avatar
Lower main crankcase: D/602 3D4
Cylinder Head/Hopper: D309
Governor end plate: D40
Cover where crankshaft emerges: D5
Flywheel: D298
Lister D 18DH 1936
X-Factor, where the bewildered are wheeled out to be sniggered at by multi-millionaires.
Garak is offline   Reply With Quote
Old 24-11-16, 08:19 PM   #33
Will reply tomorrow when get home
Old 31-12-16, 03:55 PM   #34
Garak
Garak's Avatar
Default Good job my workshop floor is strong
First run of my 'D' today.
She started easily enough but she 'ran away' and I had a hard time controlling her. The governor was trying to close the throttle plate (butterfly) but I don't think this is closing fully and reducing airflow.
The only way to stop the engine is to close the fuel regulator to the 'stop' position and hold the air valve down.
I'm going to remove the carburettor tomorrow and have a look around, it's had a new gasket fitted.
I think the engine is getting to much air, what do folks here think?
https://youtu.be/eI7NY8xjoeM
Lister D 18DH 1936
Old 31-12-16, 05:58 PM   #35
Spec 18.
I had similar problems with fast running as you are having, I ended up with another carb.
http://www.stationary-engine.net/for...ad.php?t=42105
Old 31-12-16, 06:29 PM   #36
Try adjusting the length of the vertical throttle rod to close the butterfly further, a little trial and error needed but it should work. Also make sure that the governor pushrod is fully in before starting the engine, again adjusment of the rod should correct this if it isn't.
Old 16-06-17, 08:43 PM   #37
Garak
Garak's Avatar
So, after a few runs when my D tried to start a small earthquake and with the help of folk here I've slowed her down and now she runs quite nicely
Garden crank-up
And with the Stuart pump attached.
Stuart type AF2E12
Lister D 18DH 1936
Old 16-06-17, 09:29 PM   #38
Seems OK to me Martin.
Old 20-06-17, 10:25 AM   #39
Garak
Garak's Avatar
Thanks Pete
Just waiting for this damn hip to be replaced and getting a tow-bar on the Honda and I'm good to go!! at least I can enjoy it in the garden in the mean time
Martyn
Lister D 18DH 1936
