Old 28-10-13, 05:29 PM   #1
timothygstokes
timothygstokes's Avatar
Default Lister D Type Oil
Hi all,
I've got a Lister d type but I don't know the oil capacity. Can someone tell me what it is please, as I need to purchase the oil for it for an oil change.
Thanks,
Archivist for The Unofficial Lister D Type Owners Register
1945 Lister D Type 1 1/2 HP(26DH196040), 1942 Briggs & Stratton Model I (63981), Villiers C12 Gen Set (257351), Climax Water Pump.
timothygstokes is offline   Reply With Quote
Old 28-10-13, 05:34 PM   #2
mo3mini
mo3mini's Avatar
Originally Posted by timothygstokes View Post
Hi all,
Thanks,
Hi, the D type holds very little oil. Get a 5 litre can of SAE-30 and that will probably see you for years of oil changes. Im pretty sure I put less than a litre in mine. Just fill it on level ground until oil reaches the top of the filler neck.
Don't forget to give it a good run before draining the oil
Old 28-10-13, 05:39 PM   #3
Does that really make any difference?
Not saying you are wrong Dan but I have always thought if you drain the oil when cold then you have all the oil in the sump to start with thereby you get more oil out, if you run the engine then drain the oil out then a lot will be splashed all over the inside of the engine so will stay there. I do mine cold, just the way I am.
Old 28-10-13, 05:54 PM   #4
timothygstokes
Thanks mate, I will have a look down halfords and see if I can get some.
Thanks,
Old 28-10-13, 05:55 PM   #5
mo3mini
mo3mini's Avatar
It probably makes very little difference if any lol I guess its a case of how mucky the oil is, and if your going to give the sump a clean out or not. I do mine warm because thats the way I was shown by dad. But I was also told that warm oil drains better and pulls most of the sludge and crud with it from the bottom of the sump?
Tim, not so sure if Halfords sell it or not. I think I went for some and didn't get much joy, they only seem to sell the little 1 liter bottles for the little mowers. I bought a can of Morris Lubricates SAE-30. Golden film I think it was? Recommended to me by the forum. I think Comma also does a SAE-30. Which was also recommended to me via the forum. I just choose the Morris lubricants because I knew a little local shop where I could get it.
Both can be had on ebay if you can't find it in store
Old 28-10-13, 06:01 PM   #6
timothygstokes
Would this oil work? : http://www.halfords.com/webapp/wcs/s...egoryId_165581
Old 28-10-13, 06:13 PM   #7
No need for even part synthetic oil.
SAE30 is still widely available, and cheaper. E.g. http://www.nielsencdg.co.uk/acatalog...FceWtAodm1UA0Q
Old 28-10-13, 06:49 PM   #8
You shouldn't need an oil change yet Timothy, it's only been in there a week! Wilkinsons own brand 20-50 is what I use, 9 for five litres which will last you until you have Grandchildren.....
Old 28-10-13, 06:49 PM   #9
timothygstokes
Thanks Dan, I'm going to order this one.
Thanks,
Old 28-10-13, 06:55 PM   #10
Thanks,
Learn to search google and ebay, it's cheaper elsewhere... I get mine from an independent motor factor, who is a lot cheaper than halfrauds.
