Old 19-05-13, 12:14 PM   #21
roxburd
Thanks novo, that's destroyed any shred of optimism I had left ;-)
Well, I guess the message is that it will come off, one way or another!
roxburd is offline   Reply With Quote
Old 19-05-13, 12:19 PM   #22
The Fowler key was a bit extreme. I'd never seen one stuck that hard. I'm sure your's cant be that bad.
Old 19-05-13, 02:03 PM   #23
Karragullengine
Karragullengine's Avatar
Re weld and try again, my petter AV1 broke a couple of times before i got it to move. In the end what i did was knock the key in a fraction, this was to makes sure the rust seal was broken, after that it took some hitting but it did come out. Hardest one i have ever come across but i haven't come across many in my short time restoring engines, only four but they came out easy.
Old 19-05-13, 09:58 PM   #24
roxburd
Update:
Well, I've learned a lot about arc welding and slide hammers... but the key aint moved a millimetre!
I prepped the key, threaded rod and 'fillets' properly - the edges all filed down to give a decent in-fill/bead between the bits being welded. Also chipped and brushed between beads. Got a weld I'm dead chuffed with AND kept the mask between me and the piece for every arc!
So now I have a weld I can't break!!! The limiting factor now is that I have an M10 threaded rod welded to the key but I don't have a proper slide - I've been using my 1 ton vice clamped round a bit of steel tube to avoid damage to the vice jaws... and I can give the assembly a damn good smack with that - enough of a smack to make the entire engine and trolley base jump across the floor... but the key wont move. Physically, I could give it a bit more welly but the vice just aint the right thing to use - it swivels and comes away from the rod.
Anyone in the IP5 area with a M10 slide hammer weight I could borrow??
Cheers!
Dave
Old 19-05-13, 10:05 PM   #25
Andy B
Andy B's Avatar
Dave,
Are there any scrap metal dealers near you that you could go to. You could have a look at if they have a lump of something you could use. It's not so much brute force, but the percussion of multiple hits quickly.
You are nearly there fella!
And...... Where are the photos? Pop some on, and some of the more expert guys may be able to help with ideas.
Andy
"You can only make as well as you can measure" Joseph Whitworth 1803-1887
"Insanity is doing the same thing over and over again but expecting different results."
Andy B is offline   Reply With Quote
Old 21-05-13, 12:25 PM   #26
roxburd
Andy, as requested, photo!
Not the greatest weld in the world but it's holding up so far...
I'll post a more complete set up photos on my main project thread (and link from here) since there's photos of the engine before it was disassembled on there.
Cheers!
Dave
Old 21-05-13, 12:28 PM   #27
Water skier 16
Dave,
if you are looking for tips on arc welding here is a tutorial.
http://www.mig-welding.co.uk/arc-tutorial.htm
James
1973 lister LR1 and a Lister Domestic water pump
Water skier 16 is offline   Reply With Quote
Old 21-05-13, 12:32 PM   #28
roxburd
Originally Posted by Water skier 16 View Post
Dave,
James
Ha ha! Very diplomatic, James!
Old 21-05-13, 01:08 PM   #29
Water skier 16
haha, i cant weld at all so i am in no position to comment on the welds but i guessed you want to improve so i thought i would post the link.
James
Old 21-05-13, 01:19 PM   #30
Andy B
Andy B's Avatar
Cooo Cooo
Only messing. Thing with welding is practice, and seeing what happens as you alter the current settings. Your weld certainly looks like it would hold up to some slide hammering, so just have a look about for a heavy lump to use.
Try giving the flywheel a bit of a tap towards the engine. It may help free up things a little. You are only talking fractions of a thou.
Good luck, and your nearly there fella.
Andy
