Old 04-02-13, 10:57 PM   #11
listert
No too much compression is not possible unless you skimmed half the head off
I think it,s a fuel problem.
Because the mag works fine on another engine
Brian
lister d 1952 wolseley wd9 wasserknecht waterpump lister L type cunewald 1h65
listert is offline   Reply With Quote
Old 04-02-13, 10:58 PM   #12
ant
Originally Posted by Windrush View Post
Is it running too lean on the mixture? When you start it does it black smoke, if so then just screw the mixture wheel in until it just stops smoking and that should be correct. One of my D's would start easily without any smoke but would cut out after several minuites, I had to rotate the mixture control another turn anticlockwise and it now runs fine.
hi pete there s know black smoke and i have tryed the the mixture wheel in diffrant posions and theres two possions run and stop which is stamp in the wheel and will only run when i put the wheel to run
ant
ant is offline   Reply With Quote
Old 04-02-13, 11:33 PM   #13
jmcgrath
jmcgrath's Avatar
Well try some of these;
set the tappet Clarence to .020in
use a Loge BBl spark plug or equivalent.
fuel line blockage
James
Too many engines to list
Old 04-02-13, 11:41 PM   #14
RobSmith
RobSmith's Avatar
Is the float floating realy well?
If it is half full of water or fuel it might only be floating 'gently' and the vibration from the engine may un-seat the needle and let in too much fuel and cause it to flood.
Just an idea
It might be worth a blow out with an air line.
Rob
Old 04-02-13, 11:54 PM   #15
ant
Just an idea
Rob
cheers for the replay
i have tryed that this afternoon and totaly stripped and re-cleaned the carb and anual float
wondering if the the needle could worn down if its possible
ant
Old 05-02-13, 12:05 AM   #16
RobSmith
RobSmith's Avatar
ant
take the float out and set the fuel level manually on the tap
Old 05-02-13, 12:07 AM   #17
ant
will try that in the morning
cheers ant
Old 05-02-13, 12:11 AM   #18
RobSmith
RobSmith's Avatar
cheers ant
You're not going to try it now... nobody will be in bed yet. It is only 11:20pm
Edit: I'm off to bed... pooped
Old 05-02-13, 12:14 AM   #19
ant
Just try undoing the wheel some more Ant, you may have to press the little plunger down, it might give it more fuel. What was the correct setting 60 odd years ago might not be the same now, wear and tear takes its toll!
Old 05-02-13, 12:16 AM   #20
ant
think the misses would be get upset
