Old 04-02-13, 10:03 PM   #1
ant
Default lister d 2hp starting and running problem
hi
i am having a problem with my 2 hp lister d, i have rebulid it up and cant get it to running for more then a couple of minutes
i have put all new gaskets on, head gasket on and new piston rings, as compresson was abit poor and water was leaking into the cylander when i first got it
i have cheched the mag and cant find a problem with it and set the valves at 31tho and made sure the timing is correct at 20degress before tdc
was wondering if any1 else has had this problem before and may know the problem
ant
ant is offline   Reply With Quote
Old 04-02-13, 10:08 PM   #2
RobSmith
RobSmith's Avatar
I'd guess it could be...
insufficient fuel... run it with the float chamber lid off and see if the float still stays floated.... unless you have nice paintwork as fuel might slop everywhere. Edit: ensure you don't set light to your shed whilst doing that.
The mag could be playing up after a short while or it could be the plug playing up as it warms up.
I would swap the plug or investigate that first.
Rob
Old 04-02-13, 10:11 PM   #3
steve-v12
steve-v12's Avatar
31 thou is a huge valve gap !
I know it states that gap in some books but 12-15 thou is much better.
All my Lister D's including my daughters 2hp are set at 12 thou.
Steve :)
1949 Lister B. 1941 Bamford EV3.
1941 + 1949 lister d. Sectioned lister d.
Carera saw bench, Petter A. Petter A1.
steve-v12 is offline   Reply With Quote
Old 04-02-13, 10:14 PM   #4
ant
cheers for the replay rob
i have tryed 3 new plugs in and didnt make any diffrance and i ran the mag alday yesterday on my other lister d and theres plenty of fuel in the float chamber
ant
Old 04-02-13, 10:30 PM   #5
RobSmith
RobSmith's Avatar
ant
hmm ??
Old 04-02-13, 10:31 PM   #6
ant
same hear to be honest
Old 04-02-13, 10:34 PM   #7
ant
Steve :)
hi steve i have also tryed that with the valves all this morning
ant
Old 04-02-13, 10:42 PM   #8
listert
Is there still compression when it stops?
My D had a worn valveguide so a soon as it warmed up the exhaust valve would get stuck and stay open.
Regards Brian
lister d 1952 wolseley wd9 wasserknecht waterpump lister L type cunewald 1h65
listert is offline   Reply With Quote
Old 04-02-13, 10:46 PM   #9
Is it running too lean on the mixture? When you start it does it black smoke, if so then just screw the mixture wheel in until it just stops smoking and that should be correct. One of my D's would start easily without any smoke but would cut out after several minuites, I had to rotate the mixture control another turn anticlockwise and it now runs fine.
Old 04-02-13, 10:50 PM   #10
ant
Regards Brian
hi brian theres no problem with compression as it will start back up stright after it has stopped and run again for a few minutes
but dont know if theres such a thing as too much compresson for lister ds as is bit hard to turn the starting handle when it bulids up compression
ant
