Old 17-06-18, 10:06 PM   #1
Matt_Hedges
Matt_Hedges's Avatar
Default Farm fresh lister D
Well after picking this farm fresh 1942 lister D shearing set up on Monday she is now running.
The exhaust valve was stuck solid and there was a bent push rod because of it. So after taking the head off I then saw the valves and seats where very bad. So I sent that off for the valves to be remachined and the seats to be 're cut. Then after a good check and clean out inside she fired up.
The engine has been on the same farm all it's life and the story was also confirmed by Doreen too. It is all original and I do have the cables they arenít just soaking in oil at the minute to free off, Here is a few pictures and a video.
https://youtu.be/RNMi8yyQs_I
File Type: jpg A95F8E7B-D088-41F9-849A-53DA9BB459DE.jpg (85.5 KB, 50 views)
File Type: jpg 47A1451B-2ED3-4982-A45B-7CFDB0C67B4E.jpg (52.3 KB, 44 views)
File Type: jpg 09246F12-A81F-4E2D-957E-20AC3DE0FCA8.jpg (51.6 KB, 40 views)
Matt
1936 reverse rotation Lister D, restored lister H1, 1929 shaft drive Lister D, unrestored lister H1, Bamford EV1 1944, Ruston 6PB 1938, Lister H2, Norman T300 lighting set
Matt_Hedges is offline   Reply With Quote
Old 17-06-18, 10:27 PM   #2
Looks and sounds nice, will make a good "working clothes" show engine.
