Old 19-10-15, 11:19 PM   #1
micro
Default Llister D carb
hi
I have been looking through all the threads on the Lister d page wow! what a lot of experts sure looks like a real friendly bunch of guys (and girls ?) .
I have just picked up a Lister d I don't know a lot about them yet , I have had it a week now, I have heard it running when I bought it ,I`ve been busy making a trolley for it hope to get it sitting on it next week .
the carb mixture screw has no little screws in the flat disc , if I screw it down until it stops how far do I have to screw it up to set it for starting ,I have seen videos on Utube b but there is no starting reference I was thinking to screw it down until it touches then screw it anticlockwise about a full turn I guess its a bit of trial and error.
thanks for making me welcome
mike .
micro is offline   Reply With Quote
Old 19-10-15, 11:55 PM   #2
james-barnes1
Before running it wind the needle fully shut the undo between 3/4 - 1 full turn out should be right then when running slowly screw it shut until it starts missing then give it a click open and should be fine all day
1926 lister l, 1930 lister d spoked flywheel, petter a, woseley wd2 and a petter m
james-barnes1 is offline   Reply With Quote
Old 20-10-15, 09:30 AM   #3
micro
thank you
I was in thr right ballpark then sorta remember from my motorbike days
cheers mike
Old 20-10-15, 03:56 PM   #4
Whilst james is correct I have several D's that all need different positions, my latest only needs a quarter turn to start and slightly less to run. You will learn which position works by trial.
Old 20-10-15, 04:26 PM   #5
I think Martin's right, one of my Ds gives a fair bit of leeway on the mixture screw between coughing black smoke and cutting out, on my other D just a couple of clicks is enough to upset steady running.
Old 21-10-15, 03:51 PM   #6
micro
Default lister carb
hi thank you for your replies you say adjusting the mixture by a couple of clicks mine does not click and there is no spring loaded plunger will this make a difference
mike
Old 21-10-15, 05:24 PM   #7
mike
Is the spring-loaded, wheel position retaining plunger missing? If not, do you have a photo of the carb you could show us, in case it's not the usual type?
Old 21-10-15, 06:06 PM   #8
micro
hi
its a standard carb just has the plunger missing
and the wheel has the tag instead if the two screws
mike
Old 22-10-15, 05:51 AM   #9
Chances are that the mixture screw will move either way causing the mixture to go rich or weak making running difficult.
Old 22-10-15, 01:09 PM   #10
True, try fitting a suitable standard coil spring under the mixture screw.
