Old 23-01-11, 10:49 PM   #1
st150bhp
Default belts
Hi i have no belts at the moment but i do have a bike innertube would that work?
Old 23-01-11, 11:00 PM   #2
miley_bob
miley_bob's Avatar
I wouldn't advise using an inner tube. I have seen the damage that can be done by using the wrong belting material, and it is not pretty. Just buy som proper belting as was advised last week.
Old 23-01-11, 11:03 PM   #3
Suffolkcharlie
Suffolkcharlie's Avatar
I used an innertube and it grabbed hold of my stuart turner pump and got pulled into the D's flywheel then trebuchaed it across the garden, dont do it trust me
1934 Lister DK shafty Lister LR1 genny Suffolk & Atcos Wolseley WD8 Stuart T pump Drummond 4" lathe
"Proper engines don't have spark plugs!"
Suffolkcharlie is offline   Reply With Quote
Old 23-01-11, 11:19 PM   #4
st150bhp
i would use the proper stuff but its so expensive....
Old 23-01-11, 11:29 PM   #5
Suffolkcharlie
Its woth your life trust me
Old 23-01-11, 11:31 PM   #6
miley_bob
miley_bob's Avatar
5 a meter (as quoted in the previous thread by MartinPaff) is actually pretty cheap. If your going to be using an inner tube than you cant need more than a tenners worth.
Do it with the right materials, as I have said the consequences of using the wrong stuff are not pretty when it goes wrong.
Old 23-01-11, 11:32 PM   #7
Well if it's a 5 a meter that is fairly expensive, but it will be more expensive in the long run to use the wrong thing and risk damadge. Save up the pennies....what I have to do when ever I want something.
Sometimes you will find belts at rallies. I bought several V belts at rallies, one being a scammel lorry fan belt but was long enough to use with belt pulleys, cost 1.
Old 23-01-11, 11:45 PM   #8
miley_bob
miley_bob's Avatar
For decent quality flat belting thats pretty cheap.
Old 23-01-11, 11:48 PM   #9
Ok, well it might cost a bit more from some people, but I'm sure you will agree it's worth saving for.
Old 24-01-11, 12:26 AM   #10
Do you need a flat belt? if you that desperate to try surly a V belt will do the job?
http://www.bearingboys.co.uk/A_Section__13x8_-1059-c
With a innertube you have a valve spinning around, if you take the valve out that will leave a hole that will tear under tension. I converted my push bike to tubeless, much less trouble on the rough stuff!
Cheers Steve
