Old 12-04-18, 10:40 PM   #1
dunitrong
Default Lister A and B crankshaft
Hi this is my first post on this forum so if its in the wrong place sorry. I have a Lister A that I striped about thirty years ago and need a crankshaft. Dose anybody know if a B crank will fit? Ore has any one have a crank they will part with. Thanks Dunitrong.
dunitrong is offline   Reply With Quote
Old 12-04-18, 11:42 PM   #2
Cant hep you with a crank, but yes it appears you have posted in the correct place, Oh and welcome to the asylum
Old 13-04-18, 08:29 AM   #3
Engineslune
Engineslune's Avatar
Default Lister A crank
Good morning and welcome, although not on here very often, but see your after a crank, the Lister B is different but I do have an A crank here spare, I am based in Calne Wiltshire, send me a PM if your interested.
2x Lister Ds, Stuart Tuner P55 Gen set, R2, P5M, P4 Gen set, Bamford SV3.
Engineslune is offline   Reply With Quote
Old 13-04-18, 08:12 PM   #4
allan grieve
Default lister crank
Most A and B shafts are the same only the later B had bigger main bearings Have you the spec No. of the engine you are restoring
Old 13-04-18, 09:26 PM   #5
dunitrong
Default Lister crank
Thanks for reply I will dig plate out tomorrow and post on hear .Arthur
Old 14-04-18, 11:19 PM   #6
dunitrong
Default A crank
Found the spec plate for my A Its a spec A28S. The B crank i found on ebay and no idea of spec. Engineslune i sent you a message did you receive it ?Thanks again for help so far Arthur
Old 26-05-18, 11:34 PM   #7
dunitrong
Hi everybody we are still looking for a lister A crank. If nothing turns up this time think I will have to have a regrind. Dose anybody have the cost of this? All the best Arth
Old 05-06-18, 04:10 PM   #8
dunitrong
Default A crank
First of thank you all that have tried to help with my crank. Ive spent quite a lot of time cleaning the one I have and going to use this one. Now more help please! The conrod has a pin to stop the big end bearing from rotating how is this held in?i have metal and can make one but the hole is only 4 or 5 mm deep with no threads visible. Thanks Arthur
