Old 10-09-18, 09:39 PM   #1
Sdarmstrong
Default Stuart turner pump
Hi people .
Is there a way to remove the washer on the valves on the old Stuart turner pumps ? Id like to fit fresh washers but Im afraid of breaking the valve . Any ideas ?
Sdarmstrong is offline   Reply With Quote
Old 10-09-18, 09:57 PM   #2
chrismac
chrismac's Avatar
Have a look at this for an idea of a strip down, I have one but its been that long since I stripped it I cant remember, I made new springs for the non-return valves so must have taken the part with the washer apart,
https://www.showerdoc.com/stuart-tur...34-pump-spares
Chris
Old 10-09-18, 11:26 PM   #3
Ive not long cleaned my one out, the rubbers just lift out, nothing to hold them bar the casting above or below the rubbers. No gaskets on the latest ones either
Old 10-09-18, 11:33 PM   #4
Sdarmstrong
There is a cross on the casting that stops the rubber falling off the metal valve face .
