Go Back   UK Stationary Engine Forum > Main Engine Section > Engine-Only Stuff > Petrol Engine Section
Old 11-01-18, 03:12 PM   #1
mkent
Default JAP 3 Stuck flywheel removal
I've got a well seized JAP 3, there are no puller screw holes around the boss of the flywheel, if I lever the flywheel around the edge it looks like the steel boss will separate from the sot metal the flywheel is made of.
Am I missing anything? All thoughts welcome.
M
Marcie
mkent is offline   Reply With Quote
Old 11-01-18, 03:42 PM   #2
I think that they are on a taper, try replacing the nut so that it is flush with the end of the crankshaft threads and give the nut a sharp clout with a hammer while levering the flywheel. This should 'shock' it off.
Old 11-01-18, 07:51 PM   #3
mkent
Thanks for the idea Pete, I'll give it a go when I'm back at the yard this weekend.
Marcie
