Old 09-01-18, 09:17 PM   #1
antiBRIGGSANDSTRATTON
Default Fairbanks ZD
Picked up a little FM ZD last weekend but having no luck getting it to start, good spark, and fuel, ignition timing is right, I have tried several plugs to no avail, all I can get is a few spits through the carb,are there any particular tricks with starting these engines?
Proper Job!
Matt H
Old 10-01-18, 10:12 AM   #2
There's a set of instructions HERE if that's any help.
Old 10-01-18, 07:19 PM   #3
Cheers Martin, I couldn't fine much on them, however I have managed to get it running now, and it starts fairly easily, it seems very sensitive to where the mag is timed compared to most engines, for such a crudely made engine it runs quite well, tomorrows jobs are to make a rotating grip for the starting handle that actually rotates, and an adaptor to allow me to use 18mm plugs in it, rather than 22mm plugs that are 15 odd each
Proper Job!
Matt H
