Old 15-02-09, 09:05 PM   #1
Scanner Man
Default Lister D SR1 Magento
I have an SR1 magneto for my Lister D, and have a good spark when I spin it fast by hand on the bench, but when I fit it to the engine and turn it with a handle, I can't seem to spin it fast enough to get a spark. Why would this be, and what could I do to sort it?
Many Thanks,
Lewys
Scanner Man is offline   Reply With Quote
Old 15-02-09, 09:14 PM   #2
antiBRIGGSANDSTRATTON
maybe not sparking under compression? replace the condenser first cos they cost about a fiver
Matt H
1947 D & F pumpset, 1943 close couple Lister Pumpset, 1931 & 1929 D types, 1929 Bruston D, 1930 Crossley 1030, 1942 Fowler PA, 1943 Fairbanks ZD, 1945 WD2, 1946 Bamford EG1, 1930 Superbloc 3hp, 1934 Conord F2, 1942 Ruston PT + driven equipment
Old 15-02-09, 09:27 PM   #3
Bulbous
Bulbous's Avatar
Hi Lewys
I had this problem last year with our 'scrapheap challenge D' that we were trying to get going at our local fete: and I had to clean the points about 5 times, and eventually it sprang int life. I think it was just a coating of verdigree on the points.
Dave
Bulbous is offline   Reply With Quote
Old 15-02-09, 09:29 PM   #4
The wild eye
The wild eye's Avatar
Make sure you are getting a good conection between the engine casting and the body of the mag
Steve
Old 15-02-09, 09:42 PM   #5
Scanner Man
Hi all, thanks for your replies, I think I should elaborate a little more. I haven't got the spark plug screwed into the head, I have just been testing by touching the spark plug to the magneto housing. When i spin it fast by hand, I have a good spark, but when I put the chain on and crank it by hand, zilch.
Many Thanks,
Lewys
Old 15-02-09, 10:11 PM   #6
My PT is exactly the same but when I put the same mag on my D it fires straight away, take it off and put it back on the Ruston...dead! Take it off, spin it once by hand, put it back on and it will run all day. Taking it to my mag man soon to get it right for the coming season.
Old 18-02-09, 06:43 PM   #7
Bulbous
Bulbous's Avatar
Hey Lewys
Engine149 has one for sale, if it is the right rotation? http://www.stationary-engine.net/for...ead.php?t=7168
Dave :)
Old 18-02-09, 07:40 PM   #8
miley_bob
miley_bob's Avatar
Many Thanks,
Lewys
Before you go spending any money on condensors or another mag as has been suggested, follow the instructions on the link below which were written by a friend of mine who rebuilds mags in his spare time. It will save you a lot of hassle in the long run and is some of the best advice I have come across online regarding magnetos.
http://www.internalfire.com/modules....ewtopic&t=1393
Old 18-02-09, 07:57 PM   #9
AndrewLincs
AndrewLincs's Avatar
Thanks for that link Mike.
Post printed out and stored in my useful file!
regards
Andrew
Apparently, you can polish a turd ...
AndrewLincs is offline   Reply With Quote
Tags
lister d, lucas, magneto, spark, start
