Old 05-08-17, 10:52 AM   #1
Doodlebug
Default Using a Lister D as a generator - most power possible.
Dear all,
I have an unusual (ish) question in that I want to use a lister D to generate as much power as is possible.
I have a narrowboat and to cut a long story short the lister at the front of the boat will drive an alternator which will then power an electric motor at the back of the boat.
The minimum I need is 24v at 30a however the more I can get the better. 45a would be ideal.
By my rough calculations that is just over 1 KW so the lister should cope. I was going to rig it up using a belt around the flywheel.
Does anyone have any thoughts on this - will the lister struggle to cope?
Many thanks for any help you can give!
Thomas
P.s. - Am I right in saying an alternator does not give any resistance until the field windings are powered up? So you could start the engine easily by hand before flicking a switch to put load on the engine?
Doodlebug is offline   Reply With Quote
Old 05-08-17, 11:11 AM   #2
Brian Davis
Dont Know about the power side but your PS is correct. You have to energise the alternator before it starts to generate.
Brian Davis is offline   Reply With Quote
Old 05-08-17, 11:13 AM   #3
It will work but your engine will be working at full load and will suck petrol out of fashion surely a small diesel would be better particularly an aircooled one, you will have to sort cooling for the D as it will boil nicely.
Old 05-08-17, 11:15 AM   #4
Welcome to the Forum, Thomas.
You may find that a belt on the flywheel will slip at 1kW, getting B size grooves machined may be better.
There is no significant drag at low rpm, so starting should not be a problem.
A CAV alternator should give you plenty of grunt, I have a new AC203/60 under the bench, max output available at 1500rpm :
http://www.prestolite.com/literature...ily_manual.pdf
It is a cradle mount sealed type.
Old 05-08-17, 11:17 AM   #5
You normally flash the field through the warning light, cut-in speed is 750rpm for the AC203.
Old 05-08-17, 11:18 AM   #6
Doodlebug
Thanks! Yes it will use more petrol but how much is too much. Surely not that much more than a standard generator might use. Though of course it is less efficient.
Long term a diesel would be much better. But want to test the idea with what I have as a) I don't want anything that revs too quickly as a slow engine sounds rather nice and an air cooled seems not to. B) trying to get hold of a lister CS at a good price is proving difficult and then loading it into the boat will be a job! Once this works I'll see what I can upgrade!
Old 05-08-17, 11:22 AM   #7
'Old school' plant generally allows about 2hp of engine for every kW of electrical output.
Old 05-08-17, 12:09 PM   #8
Luckily the plucky Lister D comes in a 2hp version, however, it will be running at 1000rpm to achieve this and, you say you don't want anything that revs too quickly (undefined).
However, if you have room for a Lister CS, but still want a petrol engine, then why not consider a Lister A type, 3 to 3.5hp at about 600rpm.
Old 05-08-17, 12:41 PM   #9
I have an 18 month old 2Kw four stroke generator with a approx one gallon tank which runs 3 - 4 hrs a night charging my mobility scooter and running a 1000 watt oven for 6 days at Dorset and I still have fuel left over but my 2hp Lister D Hamworthy compressor set uses a gallon a day for five days with the compressor off load.
Old 05-08-17, 01:27 PM   #10
1956ld1
1956ld1's Avatar
why not a lister aircooled diesel such as a ld1 or if you want more power, a st1. both are relatively easy to find, cheap to run and have good low revving power.
Tags
alternator, amps, generator, lister, lister d
