Old 16-05-13, 08:44 AM   #11
Kevbuts
Kevbuts's Avatar
Fantastic result Derek Bet you're over the moon with that - I know I would be. That new paint has done a half decent job of preserving the original paintwork and decals it seems
Glad the engine is mechanically sound too.
Kev
1905 Robinson A4, 1905 Robinson X Type, 1910 3hp International Famous, 1923 Little Pet, 1930 Ruston ZPR, 1933 Ruston 6PB, 1937 Lister D, 1939 Ruston PT
Kevbuts is offline   Reply With Quote
Old 16-05-13, 07:45 PM   #12
derek_patterson
derek_patterson's Avatar
The water level marker came out well too although the flash from camera makes it look a little washed out and doesn't do it justice.
If you look closely you can see a large run in the original paint below the transfer.
Derek
derek_patterson is offline   Reply With Quote
Old 16-05-13, 07:57 PM   #13
derek_patterson
Hi Kev,
I was a little undecided about it's fate when I first got the engine home but it looks like a keeper now. Anyway between us our family collection doesn't have a 'D' and it doesn't need much shed space. The engine doesn't really seem to have spent any time lying out so everything came apart really easily and rust is minimal.
It was tempting to try and get it running straight away but I'm glad I resisted because the rocker cover was removed from the engine when I got it and a lot of flakey workshop crud from previous storage seemed to have found it's way down into the sump.
If I had the flywheel key out I can finish the strip down and then I'm ready to reassemble and run
Derek
Tags
domestic pump, lister d, new purchase, original paint, restoration
