Go Back   UK Stationary Engine Forum > Main Engine Section > Engine-Only Stuff > Engine Identification
Old 02-06-10, 01:41 PM   #1
Mrsteamdan
Mrsteamdan's Avatar
Post Villers mk12 what year & usage
i picked up a nice kick start villers for a fiver at a local rally im not sure on the usage and year any ideas guys?
Mrsteamdan is offline   Reply With Quote
Old 02-06-10, 01:50 PM   #2
Looks like a grass cutter engine, one of the larger 24" type.
That series of engines was around from the 1950's onwards.
Old 02-06-10, 01:57 PM   #3
Mrsteamdan
Mrsteamdan's Avatar
thanks i was thinking somthing like that its a 120cc villers its says mk 12,hs on the plate
Old 02-06-10, 02:02 PM   #4
yeah the mk12 is a 120cc version of the 98cc mk10.
Mine is a high speed model and so has a lighter piston.
Old 02-06-10, 02:07 PM   #5
Mrsteamdan
Mrsteamdan's Avatar
thats nice mine doesent have a brass flywheel im not sure on the piston ethier ill have to check
Old 02-06-10, 02:58 PM   #6
andrew ford
andrew ford's Avatar
it could be off an atco kick start
villiers mk 12hs crosscut, mk 12/1, mk12/2,
mk 10/2hs, mk 15, mk 24c, mk 25c, jap 2a
and a lister lt1
andrew ford is offline   Reply With Quote
Old 02-06-10, 04:23 PM   #7
Mrsteamdan
Mrsteamdan's Avatar
could be it has a nice strong pulley on it so it was driving somthing all its life
Old 04-06-10, 08:07 PM   #8
Kingpin15
Regarding its accurate age, check the flywheel rim. You should have a series of stamped numbers/letters. There should be long series of number then a space then two numbers which should relate to the year, ie you might have 123456789 66, the 66 bit means 1966. Not all villiers have these stampings however. You might be lucky. If your flywheel hasnt been stamped you have very little chance of accurately dating it. If your plate is stamped Mk12 HS, the HS bit means High Speed.
It looks to be a very complete engine. Your missing the cap off the silencer, but I wish I could find a villiers that complete. Mine have all been basket case jobs, and needed a ton of spares to get going again.
Hope this helps a bit.
Steve B
Kingpin15 is offline   Reply With Quote
Old 04-06-10, 09:40 PM   #9
Mrsteamdan
Mrsteamdan's Avatar
yess thankyou we have a breaking point it does have numbers on the flywheel also its a high speed model too aparentlly according to the google search some kickstart mk12s were used in the army i wouldent of thought it would of been on a mower becuase the only kick start ones would of been the villers mk1
Old 05-06-10, 06:08 AM   #10
Mrsteamdan
Mrsteamdan's Avatar
it says "M26630"VILLERS"ENGLAND this is on the flywheel
also randomlly stamped is
R325B,A71E.559
anyideas?
Tags
dennis z type, lister d, lister lr1, villers mk12, villers mk3
