Old 23-05-10, 01:50 PM   #11
dhussey
im having same problem mine fired 10 times yesterday and nothing since then but a wet plug!
Old 23-05-10, 02:09 PM   #12
Mrsteamdan
Mrsteamdan's Avatar
They will be a pain ! ive wasted my whole weekend tying to get it to go im sure its in the corect postion to spark just flood as usual!
Mrsteamdan is offline   Reply With Quote
Old 23-05-10, 06:23 PM   #13
janner
Look for the ign mark on the flywheel and if its a clockwise rotation d then viewed from the flywheel side measure approx 2 inches to the right of the mark and scribe a pencil line, now adjust the points to just be opening at that point and all should be working fine, if its flooding and getting wet check the float ahsnt punctured also by taking out straight away and shaking and listening for a sloshing sound inside, cheers jon
Old 23-05-10, 07:08 PM   #14
Mrsteamdan
Mrsteamdan's Avatar
Only problem is mines has no ign mark has top dead centre thow and a dot halfway thow i though it was the ign mark but it would make it fire at the wrong time
Tags
dennisz type, lister d, lister lr1, lister pump
