Go Back   UK Stationary Engine Forum > Main Engine Section > Engine-Only Stuff > Painting & Preparation
Old 15-04-10, 08:53 PM   #1
Mrsteamdan
Mrsteamdan's Avatar
Smile Restoring a lister D paint issues
I need to after ive primed it some paint wht paint can i use witch will work with cellulose primer (red oxide) any ideas guys?
Mrsteamdan is offline   Reply With Quote
Old 15-04-10, 10:16 PM   #2
engine junkie
engine junkie's Avatar
you can use a good paint on top of the dried cellulose like a machine paint but not cellulose on top of an oil based paint as it acts like paint stripper so you should be ok
engine junkie is offline   Reply With Quote
Old 16-04-10, 07:11 PM   #3
Mrsteamdan
Mrsteamdan's Avatar
thanks im going to to use the red oxide to prime it then is the mid brunswick paint from http://www.stationaryengineparts.com...ne-enamel.html
thanks dan
Old 17-04-10, 12:49 AM   #4
engine junkie
go for it mate you should be fine
Old 17-04-10, 08:50 AM   #5
Sounds like it will look nice indeed, I'm using the same paint on my Ruston at the moment but the Bronze green which looks loveley! It's craftmaster paint and I recon you could get it for less if you buy direct.
Old 17-04-10, 09:00 AM   #6
janner
Phill, i,m doing my 8pb at mo, some parts have had four brush coats now and still dont have that deep gloss i was expecting, my paint is mid bronze from stationaryengineparts aswell , the carb has glossed up beautiful with two coats, but the mag mount and RH rear inspection door and governor casing are the ones thats needing extra paint, i wondered if anyone else has any tips on this paint, it is well stirred and am using a high quality brush, janner. p.s the flywheels will be sprayed black and 2 pack so dont have to brush paint them.
Old 17-04-10, 08:08 PM   #7
Mrsteamdan
Mrsteamdan's Avatar
sound good my friends buying mine offl the net from the stationary engine parts so i cant wait to put it on my engine shall i add my restorationg pics on the fourom?
Tags
and lister domestic pump, lister d, lister ld1, villermidget mk1
