Old 13-05-16, 08:21 PM   #1
Terry1943
Default Reverse rotation
Advise please,
On an anti clock rotation Lister "D" are the two ports in and out swapped around? the one I have acquired, the inlet valve is furthest from the spark plug hole and on the left of the exhaust, is this correct?
Thanks
Terry
Terry1943 is offline   Reply With Quote
Old 13-05-16, 10:19 PM   #2
Numpty
Terry,
Yes the ports are swapped. The carb will be nearest the tank and should have a right handed butterfly spindle. The governor arm will also be on the left side nearest the governor if that makes sense.
Old 15-05-16, 09:55 PM   #3
Terry1943
Thanks Mark.
Engine runs, but a bit of smoke I don't have time to sort it before Copthorne, at least it runs.
Terry
