Go Back   UK Stationary Engine Forum > Main Engine Section > Engine-Specific Forum Sections > Lister D & F
Old 10-08-16, 04:34 PM   #1
crickleymal
Default Dent in gasket mating surface
My lad's D has acquired a slight ding in the top surface of the cylinder. It's very slight, probably only 0.25mm deep but is close to the edge of the bore although not quite right on the edge. Short of skimming the surface is there any other method of filling the dent? Liquid gasket or something?
Thanks
Malc
Old enough to know better.
crickleymal is offline   Reply With Quote
Old 10-08-16, 05:17 PM   #2
If the piston passes over it without any problems I wouldn't worry about it.
Jjust re read what you wrote, is it in the bore or where the gasket sits, again I wouldn't worry about it, when I put on a new gasket I smear grease on both sides of the gasket and nothing else.
Lister M is online now   Reply With Quote
Old 10-08-16, 06:01 PM   #3
crickleymal
It's where the gasket sits but quite close (within 1mm or so) of the bore.
Malc
Old 10-08-16, 06:10 PM   #4
As I said I wouldn't worry about it.
Old 11-08-16, 09:07 AM   #5
crickleymal
Okey Doke. Thanks
Malc
Old 11-08-16, 02:10 PM   #6
Combustor
Combustor's Avatar
Default Slight dings
Have got away with re-fitting rather pitted or scored surfaces using a thin smear of anaerobic liquid gasket maker, (Loctite etc) Hardens quickly when assembled and air is excluded. Not cheap to buy, but you may be able to borrow just a small dab of it. Works for me.
Combustor.
Old Iron In The Outback, Kimberley, West Australia.
Toys include Ruston 3VQ, Lister CS 8/1, VA SOM plant.
Combustor is offline   Reply With Quote
