Go Back   UK Stationary Engine Forum > Main Engine Section > Engine-Only Stuff > Hot Air / Stirling Engines
Old 25-02-18, 11:11 PM   #31
Originally Posted by nickh View Post
(snip) boils after about 20 mins
Looking to add a small tank or rad, don't you just love the random collection of threads model engineers seem to use - top water connection is 3/8" x 24 TPI i.e. UNF while the bottom looks to be 5/16" x 32 TPI which I think is an ME thread!
Old 25-02-18, 11:31 PM   #32
As in Newcomen?
Sort of, but instead of steam being condensed it is the hot products of combustion cooling which produces the low pressure.
That's the one, I've seen a replica of one at my local museum (Black Country living museum)
Old 25-02-18, 11:41 PM   #33
Somewhere I really must visit.
Old 25-02-18, 11:48 PM   #34
oldgit
Great place; you need more than a day.
oldgit is offline   Reply With Quote
Old 04-04-18, 12:08 PM   #35
Looking to add a small tank or rad, don't you just love the random collection of threads model engineers seem to use - top water connection is 3/8" x 24 TPI i.e. UNF while the bottom looks to be 5/16" x 32 TPI which I think is an ME thread.
Or Schrader valve apparently.
EDIT; Or not - most sources quote Schrader thread as 0.305 x 32 TPI, i.e. 7 1/2 thou smaller diameter!
Old 09-10-18, 09:06 PM   #36
Found a suitable tank so soldered in a couple of fittings, made up adaptors for top and bottom threads. Just the nipples to solder on to top pipe and hopefully it'll all hold water.
Old 28-10-18, 10:15 PM   #37
Does hold water and had a good run of over 45 minutes without boiling.
