Go Back   UK Stationary Engine Forum > Main Engine Section > Engine-Only Stuff > Other Driven Equipment
Old 12-09-17, 08:49 AM   #1
Garak
Garak's Avatar
Default New Winter Project
Bamford No 1C Corn Mill
Been stored inside for many years. It turns over freely, I'll just need to sort out the broken leg, other than that just a light clean up at first and make sure it works.
After that it's the thorny issue of whether to paint or not to paint, as with my Lister D I like the fresh 'from the factory' look but the 'oily rag' finish also looks good on some equipment. Opinions on this issue welcomed.
I think it would have been clothed in a light blue colour when new, does anyone know the actual shade of blue that Bamfords used?
I've been told it was manufactured in 1900 but the early ones I've seen all have a wooden hopper, this one has a thin steel plate one, maybe it's a later replacement.
It stands about 5' tall and weighs a bl***y ton!!!
Lister D 18DH 1936
X-Factor, where the bewildered are wheeled out to be sniggered at by multi-millionaires.
Garak is offline   Reply With Quote
Old 12-09-17, 09:21 AM   #2
Lovely machinery, I owned a similar one until I got fed up with moving it so it got sold
Old 12-09-17, 03:04 PM   #3
Personally I think if you plan to drive it with a "factory finish" engine, it would look odd if not painted to the same standard?.
On the upside, at least you will be able to wear your Windy Miller outfit when showing it
Windy Miller by Robert Starr, on Flickr
Old 12-09-17, 06:34 PM   #4
If you discover that it was light blue, then it would have been highlighted in a darker blue (something like royal blue). I had a Bamford K2 mill many years ago. We painted this light blue and the wording and raised cast edges in royal blue, It looked a real treat when completed.
Philli
Old 12-09-17, 07:10 PM   #5
K_N_S_JENNINGS
K_N_S_JENNINGS's Avatar
Nice hopper here: http://www.ebay.co.uk/itm/Original-B...gAAOSwAExZoTBO
Cheers
Simon
K_N_S_JENNINGS is offline   Reply With Quote
Old 12-09-17, 08:35 PM   #6
danthetangye
danthetangye's Avatar
Originally Posted by K_N_S_JENNINGS View Post
A cheaper one here: http://pages.ebay.com/link/?nav=item...804894&alt=web
danthetangye is offline   Reply With Quote
Old 13-09-17, 10:27 AM   #7
You got me thinking that I should slip over to my other hobby and start making wooden hoppers
