Go Back   UK Stationary Engine Forum > Main Engine Section > Engine-Only Stuff > Engine Identification
Old 07-11-17, 10:58 PM   #1
Default Engine ID, anyone?
A friend has just acquired this engine. Anyone care to have a stab at an ID?
Numquam illegitimo carborundum. 1918 Renfrew 1.5hp;C.1919 1.5hp Simplicity; undated 1.5hp Lauson Frost King. 1933 Quentin C1.
Old 07-11-17, 11:07 PM   #2
Charles,
I've just put Stover into the internet and scrolled through loads of pictures and there is a Stover which is very similar but with straight spoked flywheels.
Old 07-11-17, 11:31 PM   #3
Not a Stover.
Old 08-11-17, 09:37 AM   #4
When you say that it isn't a Stover does the owner actually know what engine it is then?
Old 08-11-17, 10:08 AM   #5
Robertsonville Foundry Engine?
Portland 2010 trip.
http://buzzcoil.brinkster.net/robert...e/page102.html
Old 08-11-17, 12:09 PM   #6
Yes, Pete, He knows what it is. Just thought I'd see if anyone else knew. Bit of a quiz!!
Old 08-11-17, 12:15 PM   #7
Yes, Peter, it's a "Robertsonville". There was controversy over what they were actually called in the first place. They were designed by a guy called Jean Thomas Bisson but actually made by Adolphe Lambert who had a foundry and engineering business in Robertsonville, Quebec. In around 1916 they were advertised in their local press as a "Robertsonville"engine.
Matey's engine has the cast nameplate on the other side of the hopper. Curiously, they never had serial numbers.
Old 08-11-17, 02:45 PM   #8
Don't mind betting that the hopper casting is symmetrical and fits either way round?
Old 08-11-17, 02:55 PM   #9
Originally Posted by pulsechoes View Post
(snip) Matey's engine has the cast nameplate on the other side of the hopper.
And I wonder if the other side of the one Peter posted has that little scallop to facilitate access to priming cup on Webster igniter?
Old 09-11-17, 01:30 PM   #10
dclf1947
And I wonder if the other side of the one Peter posted has that little scallop to facilitate access to priming cup on Webster igniter? NHH
I have two photographs from the internet of 6 HP engines, one with a scallop and one without, maybe designed out and only on the early ones?
dclf1947 is offline   Reply With Quote
