Old 24-02-13, 10:54 PM   #1
roger gurney
roger gurney's Avatar
Default spec 25 lister d
they are still out there to be found
just picked up this unusual spec 25 DH in running order
roger.
roger gurney is offline   Reply With Quote
Old 24-02-13, 10:59 PM   #2
Mowersman
Mowersman's Avatar
Oooh, Very nice. I do like D's, even more so, unusual D's.
Andrew
Old 24-02-13, 11:20 PM   #3
I like D's especially DD's...
Nice engine by the way
Old 24-02-13, 11:34 PM   #4
liammc
liammc's Avatar
im guessing this is the one off of preloved/gumtree.
cheers,
liam
www.rustyrelicsonline.co.uk
liammc is offline   Reply With Quote
Old 24-02-13, 11:52 PM   #5
Very nice! You did well finding that.
Old 25-02-13, 12:23 AM   #6
CSdiesel
Did Lister's make a mammary model ?
If they did , you'd feel a right tit rallying that
Old 25-02-13, 08:23 AM   #7
AlandEi2
AlandEi2's Avatar
Only 225 made according to the "bible"... contract engines sharing the mag drive with the "F" type, a hard life resulting in few remaining.
This is an early one, as from numbers 142596 (03-05-1938) to 154783 (25-09 1939) in spasmodic batches.
Alan.
1941 Lister D - 1939 Lister A and Stuart Generator (in progress) - 1950's BSA Field Starter - [I]all protected by electrickery, razor wire, various man traps and a rabid Yorkie... [/I]
AlandEi2 is offline   Reply With Quote
Old 25-02-13, 06:51 PM   #8
roger gurney
Default lister d spec 25
reply from david edgington
one of a batch supplied to ransomes and rapier ipswich
16/6/1938
any ideas what they would fit it too, it has a chain sprocket fitted.
roger
Old 25-02-13, 06:55 PM   #9
roger gurney
yes liam i got it via preloved
met the seller half way so not to many miles.
roger
