Old 30-07-17, 06:16 PM   #11
Originally Posted by woodsman View Post
Ebay listing has ended but contact details are there. Got one for my Petter A1 and it worked a treat.
THE BUY IT NOW PRICE IS FOR A BRAND NEW GIBHEAD KEY PULLER FOR 1 1/2" CRANK DIAMETER THAT WILL FIT LISTER A / D OR ANY STATIONARY ENGINE WITH A 1 1/2" CRANK DIAMETER MADE FROM EN19t ( HIGH TENSILE STEEL ) NO CHISELING NO BLOODY KNUCKLES NO DRLLING OUT SIMPLY PULL IT OUT WILL SHIP WORLDWIDE AT EXTRA COST OF 10 IF POSTAGE IS LESS I WILL REFUND THE DIFFERENCE CHECK MY FEEDBACK HAVE SHIPPED AND REFUNDED WORLDWIDE COMES WITH 60mm LONG HEX HEAD SETSCREWS THESE ARE OF A LOWER TENSILE STRENGHT SO IF IT STRIPS A THREAD IT WILL BE THE SCREW NOT THE PULLER THIS WILL ALSO FIT PETTER M5 ( 1 1/2" ) OTHER SIZES ARE ALSO AVAILABLE LISTER CS 2" CRANK DIAMETER RUSTON PB WOLSELEY WD ANY QUESTIONS CALL OR TEXT ME ON 07584167667
They need an intact head on the key, as well as clearance between head and flywheel to work.
Old 30-07-17, 09:52 PM   #12
I'll stick with my wedge. Far better with a stuck key than a puller.
Old 08-08-17, 07:58 PM   #13
master
Thanks to everyone who replied with hints and tips. I have got the gib key out now, just the fly wheel to go!!
master is offline   Reply With Quote
Old 08-08-17, 08:03 PM   #14
How did you get the key out?
Old 08-08-17, 08:13 PM   #15
master
I welded some threaded bar around the key, used a 4" piece of pipe against the fly wheel, braced across it and screwed it out. Lots of penetrating oil and hammering and it let go,
Russ
Old 08-08-17, 08:16 PM   #16
Result. Top man!
