Old 17-07-14, 12:50 PM   #1
pascal22
pascal22's Avatar
Default Another one in my shed !
Hi all,
Yesterday I found this engine near to my home, ('she was the toy of my father', her daughter told me).
I'll take great care of her I replied.
She's a B type spec 13 3 1/2 hp and wears number 43086
Also an engine from ''Faul et Fils'' manufacture
I think about 1924
Pascal
pascal22 is offline   Reply With Quote
Old 17-07-14, 12:52 PM   #2
Kevbuts
Kevbuts's Avatar
Hi Pascal,
That's a lovely original early Lister B you have there. I would agree on the date at 1924 too.
Bet you're very pleased with your new addition
Is she in running order?
Kev
1905 Robinson A4, 1905 Robinson X Type, Scale Rider Ericsson, Scale Otto Langen, 1923 Little Pet, 1930 Ruston ZPR, 1933 Ruston 6PB, 1937 Lister D, 1939 Ruston PT
Kevbuts is offline   Reply With Quote
Old 17-07-14, 02:46 PM   #3
PuttPuttBang
PuttPuttBang's Avatar
Très bon ! Nice and unrestored. I like the trolley, too.
1929 Ruston-Hornsby 6 AP, 1925 Ruston-Hornsby 5 IP, 1920s 50V GE dynamo.
Old 17-07-14, 03:59 PM   #4
sidecrank
Looks to be hooked up to a nice early mag. john
sidecrank is offline   Reply With Quote
Old 17-07-14, 07:09 PM   #5
pascal22
pascal22's Avatar
Hi,
Kevin,
Of course I'm very pleased with her,
She's in running order, I've started her first time but jumps like a kid !!!
Puttputtbang,
I wonder if the best would be to keep her like this (keeping the original paint)
Maybe burned lin seed to protect her.
John,
I've tried to see the mag type but a lot of grease on it
For the moment teeth-brush is my best friend.
Here you can see the ingeneer who shows me the best way to proceed
Pascal
Old 18-07-14, 07:17 PM   #6
pascal22
pascal22's Avatar
Hi all,
I've a look at the keetle of the engine and I saw a lot of corrosion inside,
Has anyone have a solution to protect inside the keetle ?
I've think about restom but I don't know if it's strong enough with hot water.
Pascal
Old 18-07-14, 08:10 PM   #7
timothygstokes
timothygstokes's Avatar
I run my lister d type with a few squirts of oil in the water so that when I drain it out, the oil is left behind and creates a film that stops further corrosion
Archivist for The Unofficial Lister D Type Owners Register
1945 Lister D Type 1 1/2 HP(26DH196040), 1942 Briggs & Stratton Model I (63981), Villiers C12 Gen Set (257351), Climax Water Pump.
timothygstokes is offline   Reply With Quote
Old 18-07-14, 08:20 PM   #8
A few old tea bags thrown in the hopper are supposed to help. Something to do with the tannin in the tea.
Cheers, Steve
Old 18-07-14, 09:01 PM   #9
pascal22
pascal22's Avatar
Ingenious
I' ll try these options or maybe try to cook an oiled tea
That's my first hooper engine so I've never met that problem.
Thanks a lot mates
Pascal
Old 18-07-14, 09:13 PM   #10
chrismac
chrismac's Avatar
There was also a thread here somewhere which recommended using one of these to hold everything together rather than the leaves and bag chocking your drain tap,
http://www.ebay.co.uk/itm/REUSABLE-T...item2a3b108f76
Chris,
I bought a few.
