Go Back   UK Stationary Engine Forum > Main Engine Section > Engine-Only Stuff
Old 21-05-18, 06:07 PM   #1
Default Tranco engine valves identification help
Hi,
I have a few Tranco (make) engine valves which I can't identify. Peter had a Tranco valve catalogue in which to look them up, but that avenue is closed, does anyone else have one?
Tranco numbers on valve stems are:
1077
487/2 EE4
1169 2 YY1
Thanks for any help with these, it would be a shame to chuck good unused valves out if someone could make use of them.
Old 28-05-18, 02:09 PM   #2
Combustor
Combustor's Avatar
Default Engine valves ID.
New valves are always useful, even without their catalog ID. If stem and head diameters and overall length are known, It is simple enough to trim length, machine collet grooves, re-grind seat angles or even reduce head diameters to suit the job in hand. Guides can be reamed up a size to suit the stems. Have never used an original valve for a replacement yet. Could always find something that could be cut to fit. Great if you have the gear, but any machine shop can usually do a fit-up that will work fine. Regards,
Combustor.
Old Iron In The Outback, Kimberley, West Australia.
Toys include Ruston 3VQ, Lister CS 8/1, VA SOM plant.
Combustor is offline   Reply With Quote
