Go Back   UK Stationary Engine Forum > Main Engine Section > Suppliers > Gaskets & Seals
Old 22-09-17, 09:42 PM   #1
chrismac
chrismac's Avatar
Default Engine block sealant, main bearing caps front and rear
All, I am looking for some assistance with sealing the block parts which hold the main bearing in my engine, there are some rubber seals but origionally there was sealant, a silicone type as it set but flexible, I was wondering what type I should use, I have hylomar blue but its non setting and was concerened it will not be suitable.
I hope that explaination is clear enough what I am after
Chris
Old 22-09-17, 09:58 PM   #2
Loctite 5900 is the industry standard engine sealant.
What engine is it for?
Old 22-09-17, 09:59 PM   #3
Chippie
I remember years ago ( 40+) rebuilding engines and using rtv silicone jointing compound but the brand name escapes me.....
Dow Corning is a good brand as is Loctite, I'm sure other folk will have their own preference
Old 22-09-17, 11:16 PM   #4
chrismac
chrismac's Avatar
Thanks for the replies, mitsubishi 3 cylinder desiel,
Chris
HTML code is On
