Go Back   UK Stationary Engine Forum > Main Engine Section > Suppliers > Gaskets & Seals
Old 01-01-17, 01:51 PM   #1
listerman2011
listerman2011's Avatar
Default Large head gasket
Hi all
I'm looking for a decent sized piece of head gasket material for a large engine,
I have changed a head gasket before on a lister d, but that was a ready made job
what I would like to know is.
1. Best type of gasket to use for a head (there are so many types)
2. Are there any decent suppliers?
Thank you in advance
Sean.
listerman2011 is offline   Reply With Quote
Old 01-01-17, 01:58 PM   #2
How large is large?
Can always get one made from gaskets to go, Google should find them ok.
Old 01-01-17, 02:08 PM   #3
listerman2011
33" l 24" w roughly
That is if I can get the head off its for a Blackstone "blister" engine
Old 01-01-17, 02:53 PM   #4
I'm guessing those inches were meant to be cm? Otherwise it's a chuffing big Blackstone vertical...!
Old 01-01-17, 03:12 PM   #5
http://www.ebay.co.uk/itm/Cylinder-H...Vo65l0P3S_HMzw
OR
http://www.gasketstogo.com/
Old 01-01-17, 09:26 PM   #6
listerman2011
This info is all I could find, it's the larger 4 hp model
Old 01-01-17, 10:10 PM   #7
Headless
Headless's Avatar
33" x 24" is the max size of the engine including protrusions such as the exhaust, fuel tank, crankshaft, flywheel etc. It is not the size you need for a gasket!!!
Andy
Old 02-01-17, 12:02 AM   #8
Is it the first of April already!?
If you want to make your own gasket, a sharpened set of dividers, a sheet of Klinger gasket material and a set of wad punches can be purchased for the job. I bought a set of cheapo wad punches (8, 3-20mm) and they are just the job for gasket cutting. A copper fibre sandwich gasket is a better bet, but making your own is easy enough - all the items required are available on ebay.
HTML code is On
