Go Back   UK Stationary Engine Forum > Main Engine Section > Suppliers > Gaskets & Seals
Old 17-08-16, 01:51 PM   #1
locknut
Default Tiny Tim gasket
Hi Guys,
I am looking for a gasket set for the carb - sorry I dont know the make- for my Tiny Tim Engine.
The only markings that I could find on the carb are shown in the photo - a Z over an F with what looks like a small m on its side next to the Z
This is the disc on top of the carb - I dont know what the numbers etc mean I am afraid.
Here is a photo of the gasket that I need to replace.
Can anyone kindly advise me where I can obtain a carb gasket to replace the damaged one shown?
Any help or advice would be much appreciated.
Thanks.
All the best,
Kev.
locknut is offline   Reply With Quote
Old 17-08-16, 02:43 PM   #2
I think the carb is a Tillotson. Not that that is going to help you with a gasket set, I suspect you will end up cutting your own.
Old 17-08-16, 07:51 PM   #3
single flywheel
Smile tiny tim gasket.
Hello I have a couple of tiny tim engines but mine is a different type sorry I cannot help but you should be able to cut one out. mike watt.
Old 18-08-16, 05:11 PM   #4
locknut
Hi Guys,
Thanks for your replies.I think that you are right in that I am going to have to make one up myself.
All the best,
Kev.
Old 18-08-16, 06:24 PM   #5
mo3mini
mo3mini's Avatar
Originally Posted by locknut View Post
Hi Guys,
All the best,
Kev.
I made my own too... I doubt you'll ever find any gaskets for the tiny Tim. Just make sure you cut all the holes in the carb gasket and it'll run like a top
Old 18-08-16, 06:40 PM   #6
locknut
Hi Dan,
Thanks for that.
Could you kindly let me know what gasket material you used? Was it ,for example , one especialy for carbs?
All the best,
Kev.
Old 18-08-16, 09:03 PM   #7
Of course I'd never use anything other than proper gasket paper (e.g. http://www.ebay.co.uk/sch/i.html?_od...paper&_sacat=0 )
but in essence pretty much any papery type stuff of approximately the right thickness will do.
Old 18-08-16, 09:40 PM   #8
mo3mini
mo3mini's Avatar
Hi Dan,
Thanks for that.
All the best,
Kev.
Yep flexoid... It's oil and fuel resistant. I think I used a .5 or .8mm thick.
Old 19-08-16, 09:22 AM   #9
locknut
Hi Guys,
Thanks for that.I have used Klingersil (c4324) gasket material before but it,to my inexperienced eyes,did not seem to be the right stuff to replace the carb gasket.
Thanks NHH for the ebay link.
Thanks Dan for the thickness guidance.
All the best,
Kev.
Old 12-01-17, 06:47 PM   #10
single flywheel
Hello I have three tiny tim engines two have the same control boxes which I have a wiring diagram for but the third has a differant single bobbin control box does anybody have a wiring diagram/
thanks in advance.
mike watt.
HTML code is On
