Go Back   UK Stationary Engine Forum > Main Engine Section > Suppliers > Gaskets & Seals
Old 21-09-15, 04:54 PM   #1
Terry1943
Default Fuel tap
Can any one help me with a supplier of cork washers for fuel taps push pull type that go right through (push on/pull off) I need 13mm & 17.5mm OD, not having much luck searching the net.
Thanks in advance
Terry
Terry1943 is offline   Reply With Quote
Old 21-09-15, 05:01 PM   #2
I cut my own from cork sheet or even cork rocker cover gaskets using hollow punches.
Old 21-09-15, 06:17 PM   #3
Have you tried George at Villiersparts?
MP.
Old 21-09-15, 06:36 PM   #4
john kyte
Available on ebay at the moment Item 202059280555 from rattlenacker
john kyte is offline   Reply With Quote
Old 03-10-15, 10:06 PM   #5
userw7279
I punched out some leather ones from an old satchel, works fine.
userw7279 is online now   Reply With Quote
Old 04-10-15, 09:00 AM   #6
How does leather hold up long term?? Sounds like a good idea
HTML code is On
