Go Back   UK Stationary Engine Forum > Main Engine Section > Engine-Only Stuff > Hot Air / Stirling Engines
Old 19-11-16, 09:44 PM   #21
skankin_giant
skankin_giant's Avatar
Done....
https://www.youtube.com/watch?v=oM6dA4hUXw0
Took more heat than I expected, it's a shame I don't have a lathe as I would like to make up some inserts for the crankshaft as it is quite sloppy!
Cheers, Steve
The Wizard from The Lizard
WW1 ABC, Brockhouse Spryt, Norman SC, Sattley TA, Scott SE, Stuart H1, K, Pre-P3 & WD, Villiers WX11
skankin_giant is offline   Reply With Quote
Old 19-11-16, 09:52 PM   #22
might be worth cleaning the piston and bore and using graphite as lubricant, that might help a little.
martin P
Old 19-11-16, 09:56 PM   #23
skankin_giant
I was wondering if some CPU heatsink paste between the pistons and the base might help. Probably wouldn't do anything...
Cheers, Steve
Old 19-11-16, 10:03 PM   #24
Looks like success to me
Old 19-11-16, 10:06 PM   #25
skankin_giant
Yes, 40 well spent, Inc sourcing the replacment flywheel.
Cheers, Steve
Old 19-11-16, 10:09 PM   #26
At least you know you've got a runner even if it's perhaps not the best advert for 'silent' running Stirling engines!
nickh is online now   Reply With Quote
Old 19-11-16, 10:15 PM   #27
skankin_giant
Indeed, not sure if I could fill the crankshaft holders with solder and re-drill the correct size.
Cheers, Steve
Old 19-11-16, 10:30 PM   #28
danthetangye
danthetangye's Avatar
Cheers, Steve
Worth a try. Or drill the housing out and fit brass bushes. RS do small sizes that may be suitable.
danthetangye is offline   Reply With Quote
Old 19-11-16, 10:35 PM   #29
skankin_giant
Thanks Dan, will have a look.
Cheers, Steve
Old 03-12-16, 05:54 PM   #30
skankin_giant
Bought a wick burner from eBay, which I have to say is very nicely made if a bit tall for my needs but it works....
https://www.youtube.com/watch?v=uwEVwr3KyS0
Those of keen eyes....and hearing... will notice the flywheel wobbling about, the holes for the crank shaft are oversized causing the crankshaft to rock back and forth with the stroke, so will need to be bushed to make it run anything like it should again.
Cheers, Steve
