Old 20-08-18, 10:28 AM   #31
miley_bob
miley_bob's Avatar
Originally Posted by Hornet 6 View Post
Never really understood how an electronic, or hydraulic parking/emergency brake can be legal.
Quote from vehicle constructions and use regulation.
Neil
EU type approval regs are superior to the construction & use regs. We have just designed and built a prototype electric powered truck and it passed type approval tests with the VCA, with an electronic park brake. So electronic park brake looks to be allowable under these regs.
Old 20-08-18, 02:23 PM   #32
Originally Posted by miley_bob View Post
Neil
Allowable yes, but sensible or safe, not so much I'd venture to suggest.
The old fashioned lever with release button between the seats is always going to be more user friendly, and as such safer.
Old 20-08-18, 03:47 PM   #33
miley_bob
miley_bob's Avatar
I agree that's its much more user friendly. I am not a fan of the modern electronic park brakes.
Old 20-08-18, 04:29 PM   #34
I used to have fun taking my Mini for MOT's, it had a flyoff handbrake conversion (useful for handbrake turns) which meant the release button worked opposite to normal.
Old 20-08-18, 05:12 PM   #35
From what I've read the worst that can happen is they don't disengage so would be safe if a little annoying, if youve owned an Astra or a Cavalier there mechanical brakes were good at sticking on.
Old 20-08-18, 08:18 PM   #36
I too really dislike the EPB. There is one benefit of it though, in an emergency it will monitor the wheel speeds and stop them locking.... That's it, the only benefit I can see. I much prefer the mechanical type and will always try to avoid buying a car with one.
Mt brother had a disco with it fitted and it started playing up, he traded it in having received a massive quote to fix it.
Old 20-08-18, 09:41 PM   #37
May only be slightly annoying to you, I can assure you that all the people who have their journey interrupted will be more than slightly annoyed.
Modern cars, to be honest I'm pretty fed up with them in general, if it were possible i'd much rather have a brand new 70's or 80's car.
Old 21-08-18, 08:23 AM   #38
Hi Neil,
The motive power for the parking brake only applies them, they are then ratcheted/held in place, without any further contribution of power (either hydraulically, or electronically) until release.
There isn't any purely hydraulic parking brakes as far as I am aware. Vehicles with rear disc brakes have either a drum brake inside the disc, or a rotating/cam operated onto the pads, both either cable or electronically operated.
Old 21-08-18, 09:44 AM   #39
Originally Posted by Paul_Sterling View Post
Hi Neil,
Make no difference to me, electronic handbrakes are not purely mechanical, electric fail and you have no handbrake, if they fail while applied you walk home.
Mankind seems to have forgotten a very important bit of advice.
"Just because you can, does not mean you should"
Old 21-08-18, 09:50 AM   #40
woodsman
"Electronic handbrakes:- a good or a bad idea; discuss. Barry."
Was given an Omega as a courtesy car once which was fitted with an electronic handbrake - hated it. Also, I Will Decide When To Switch The Engine Off Thank You!
Also got stuck with a Golf with an electronic handbrake as hire car in Lanzarote. Had to do a (lot more than) three point turn in a steep and crowded car park - nightmare!
Regards Paul
