Old 24-04-18, 10:32 PM   #1
Crash Test Johnie
Crash Test Johnie's Avatar
Default Raf blue paint codes
Hi all does anyone know the code for raf blue paint . I belive it was also called air ministry blue. As I have a trolley acc gen set to paint and it was blue under the green that had been sprayed over everything.
Cheers John
Crash Test Johnie is offline   Reply With Quote
Old 25-04-18, 10:05 AM   #2
Default RAF Blue.
Try these:-
www.ebay.co.uk/itm/162093958733
I got some aerosol paint from elsewhere on Ebay and the code was:- BS381-633
Old 25-04-18, 10:06 AM   #3
Kleftiwallah
No idea about the paint colour code, but the Royal Navy had or have a grease the same colour which they called "Crab fat". Because the similarity in colour the 'matelots' call the R.A.F. chaps Crabfats.
Ex crabfat rigger. Cheers, Tony.
Kleftiwallah is offline   Reply With Quote
Old 25-04-18, 11:17 AM   #4
Wasn't it a similar colour cream for crabs/lice?
Current Crabfat Comms Tech.....
Is it the pale blue used on RAF ground equipment or the RAF Blue Grey used on vehicles you are after?
Old 25-04-18, 11:53 AM   #5
Lifted from "Google Images":-
File Type: jpg raf colour chart ncs codes-page-001.jpg (31.9 KB, 28 views)
Old 25-04-18, 04:35 PM   #6
Crash Test Johnie
The colour for ground equipment for a 1940s "Trolley Acc" generation set.
Thanks John.
Old 02-05-18, 10:17 PM   #7
RH23
I have a ex RAF Lister A and, the colour code is BS633 RAF Blue/Grey, the colour can be purchased from Smith and Allan who are based in Darlington I believe, they are on ebay under coach paints, hope this helps, Rob
RH23 is offline   Reply With Quote
