Old 02-04-14, 06:14 PM   #1
jmcgrath
jmcgrath's Avatar
Default Craftmasters Paint
Me and my cousin has fond out that Stationary Engine Parts Paint is not good and it is not fuel resistant. I said about Craftmasters Paint but I don't know is that fuel resistant?
James
Too many engines to list
Old 02-04-14, 06:52 PM   #2
I have had no problems with SEP paint. Done my BPR with that about 4 years ago and it still looks good. All paint will "Lift" with petrol until it is really hardened off, this takes about a month. As for your question, Craftmaster paint is fine with fuel spillage after it has hardened off.
Old 02-04-14, 07:36 PM   #3
mo3mini
mo3mini's Avatar
Painted my WD2 in craftmasters paint, had a little bubble around the fuel tank. But as Appletop said I didn't allow it time to harden off. I put petrol in it and ran it a day or two after the paint had dried hehe. But that being said one little bubble in the paint is all ive had after 2 years of it being restored. Good stuff. Worth buying.
Use a primer though. Not sold on the bare metal top coat myself.
Old 02-04-14, 08:03 PM   #4
SEP used to sell Craftmaster but then changed supplier.
I have used craftmaster paints on a few engines now and find it's fuel/oil proof and gives a good finish. Like any paint, it's going to need a little time to harden off and become fuel proof.
Old 02-04-14, 08:06 PM   #5
HenryB
HenryB's Avatar
I painted my 6PB in Craftmasters paint and it all seems good, apart from around the carb where it has bubbled, I guess I didn't leave it to harden for long enough. I believe Craftamasters used to supply SEP and not their own brand, but have since changed to supplying their own brand of paint so I'm not sure on the quality of that in comparison to Craftmasters.
Henry
Stover CT2 ~ Petter M Acorn Top ~ Ruston Hornsby 6PB ~ Ruston Hornsby PT ~ 2 Lister Ds ~ Oxford Allen Scythe ~ Fordson Super Dexta
HenryB is offline   Reply With Quote
Old 02-04-14, 08:20 PM   #6
miley_bob
miley_bob's Avatar
I wouldn't use either. There are much better paints out there which are considerably cheaper.
Old 02-04-14, 08:31 PM   #7
robssk855
robssk855's Avatar
I have used craftmaster Lister green on several engines with very good results, one engine was painted 4 years ago and no sign of rust to date. But you do have to let it cure for a few weeks, the heat of the engine helps this process, so the tank will take longer to "go off".
robssk855 is offline   Reply With Quote
Old 02-04-14, 08:39 PM   #8
Never had a problem with paint lifting Myself. I use STOKES paint (about 8 per litre) and leave it for several weeks before putting fuel near it, plus I always paint the tank and carb first to give it a longer curing time. No 'weekend restorations' here....... Makes me smile at times, folk will spend 20+ on paint and then baulk at the cost of a mag rewind that will actually make the thing work!! Going back to the bunker now....
Old 02-04-14, 08:48 PM   #9
Sounds like an example of what the northern comedian Mike Harding used to refer to as "Fur coat, and no knickers"!
Old 03-04-14, 10:05 PM   #10
jmcgrath
jmcgrath's Avatar
Thanks For the help
James
