Old 13-07-16, 11:20 PM   #1
stevelew
Default Marco compressor
Hi all,
The Lister D I bought came attached to this Marco compressor
With this tank, or evaporator tank?
I'm guessing this is a refrigerant compressor from other references to the Marco name?
Now curiosity got the better of me and if it was to be of no use I may as well have a look inside
everything looks in good condition
The head is soaking in molasses at this moment as the plates and springs that hold the spring steel intake "flaps" are a little rusty
The only difference I can see between this and an air compressor is the crankcase is vented into the inlet.
I've tapped this hole with the idea of blanking it and venting the crankcase with a different arrangement on the fill plug, but before I waste any more time on this what would stop this being a useful air compressor for occasional use?
stevelew is offline   Reply With Quote
Old 14-07-16, 12:16 AM   #2
1956ld1
1956ld1's Avatar
Originally Posted by stevelew View Post
Hi all,
Its a very nice piece of kit by the looks of things, I don't own one but check out this mans setup. https://youtu.be/RWJNRaBDJxU .
Hope this helps,
Josh
Old 15-07-16, 02:49 PM   #3
ListerHA2
ListerHA2's Avatar
Are there any valves in the top of the pistons?
Old 15-07-16, 10:22 PM   #4
stevelew
No, flat top cast iron pistons.
Old 16-07-16, 02:44 PM   #5
ListerHA2
ListerHA2's Avatar
I had a similar 2 cylinder many years ago, it had valves in the top of the pistons to shift the air from the sump. A bit of a pain as they are designed to retrieve the outgoing oil mist with the return refrigerant.
Oiled the air tools well but needed constant topping up, failing that an oil separator may have been missing.
