Old 03-07-18, 03:46 PM   #61
oliver
oliver's Avatar
Thank you Nick for that picture I think I can come up with something now
petter m 3hp. mk1.bamford ev1.bernard 8hp. .swan 6.5hp. douglas ft35. bamford sd3. moteur bernard w1, bernard w2,bernard w3,2 bernard wos. bernard d1.bernard k1.bernard b2.bernard c3.bernard d1..ihc m 3hp lister l 1925,listerl l1929,listerlh1935,,baker monitor 1934,lister j 1915,,moteurs deville 1929,bernard k2,bernard d2,crossley 1030,crossley compressor engine 1040,1934 petter S,1929 crossley vo6,motour unie, lister cs 5/1 1953,bernard w13 1949,bernard R2 1926
oliver is offline   Reply With Quote
Old 04-07-18, 09:41 PM   #62
oliver
oliver's Avatar
A little more progress as this restoration draws to a close ,the new cylinder shroud came back from powder coating and the fuel tank I know it looks small but it will run this motor for a while ,the standard tank is a great big thing and I wanted to keep the cylinder as clear as possible .
The exhaust I have used is a cast iron one ive had for years when I get round to it I will fabricate some thing similar to the original pepper pot type ,I think it looks ok for now .
As you can see in this picture the small tank I've used does not look to out of place . just the trolley and a new pulley for the fan to make .
Old 04-07-18, 09:54 PM   #63
Nice work, that's certainly going to stand out as something a bit different if you rally it.
