Go Back   UK Stationary Engine Forum > Main Engine Section > Suppliers > Gaskets & Seals
Old 20-02-18, 09:12 PM   #1
Harddisk25
Harddisk25's Avatar
Default Villiers Mk3 Float Bowl Seal
Hi, I'm trying to find the fiber washer seal for the float bowl on a Villiers Mk3 Carb. It's on a Villiers Mk25a.
57mm outside, 52mm inside.
I've ordered what i thought was the correct one but it wasn't which was 50mm outside, 43mm inside.
Thanks Chris
Harddisk25 is offline   Reply With Quote
Old 20-02-18, 10:26 PM   #2
adgecutler
adgecutler's Avatar
If you are struggling to find one, make one from gasket paper.
I know nothing except the fact of my ignorance.
Jamie.
adgecutler is offline   Reply With Quote
Old 21-02-18, 02:10 AM   #3
Harddisk25
Harddisk25's Avatar
It's looking that way adgecutler. Thanks for the reply.
Old 21-02-18, 11:40 AM   #4
Hi Chris,
Have you tried L&S Engineers - they have always been very helpful to me. Maybe they could check dimensions before sending?
Old 21-02-18, 08:21 PM   #5
I can't believe that with all of the vintage motorcycles/mopeds, horticultural machines, and seagull outboards, out there using Villiers carburettors that there isn't someone making and selling these float bowl rim seals/gaskets.
air-cooled is online now   Reply With Quote
Old 21-02-18, 09:50 PM   #6
I've just spent an hour searching for Villiers MK3 carburetors and all of the Villiers sites I've come across dont list one so I searched MK25 engines and they list two carburetors one of which is similar but not the same so I went back to Villiers Services and looked at similar shaped carburetors and they all refer to a bowl gasket, why not use an o ring of thin section but the correct diameter, you may even get a square section one.
Old 21-02-18, 10:35 PM   #7
I found this, but have no idea if it will help.
Wolseley WD 8, Stuart Turner P5, Maytag 92, Maytag 72. Lister LT1.
Old 22-02-18, 11:39 PM   #8
Harddisk25
Harddisk25's Avatar
I've cut my own out of gasket paper and it's sealed it ok, also got the engine running today which you can see on my post at the Petrol Engine Section.
Thanks for all the help guys.
HTML code is On
