Go Back   UK Stationary Engine Forum > Main Engine Section > Engine-Specific Forum Sections > Stuart-Turner
Old 28-12-17, 06:20 PM   #11
skankin_giant
skankin_giant's Avatar
It's been restored so there is the possibility it's a replacement cylinder off of a genset engine.
The serial number is also sometimes stamped on the crankcase on a flat near the dipstick hole.
The Wizard from The Lizard
WW1 ABC, Brockhouse Spryt, Norman SC, Sattley TA, Scott SE, Stuart H1, K, Pre-P3, R3 & WD, Villiers WX11
skankin_giant is online now   Reply With Quote
Old 28-12-17, 07:51 PM   #12
Because we do tend to swap things around, and 30447 has had an overhaul, all things are possible. I spent a bit of time today checking the numbers before and after 30447 and did find the handwritten changes, so unless S-T made an error, that's what is in the book.
Old 29-12-17, 11:52 PM   #13
Old Lister D
Old Lister D's Avatar
Thanks for that, I will check it out next week and see if there are any more numbers on the engine, I think there is a plant number as well, don't know if that will help.
ALWAYS LOOK ON THE BRIGHT SIDE OF LIFE.
ALL THE BEST
SYD
Old Lister D is offline   Reply With Quote
