Go Back   UK Stationary Engine Forum > Main Engine Section > Engine-Only Stuff > Marine Engines and Accessories
Old 08-12-17, 01:44 PM   #1
keith-pu8
keith-pu8's Avatar
Default Drive Belt
Can someone point me in the right direction, I'm looking for a 1'3/4 drive belt 3mm thick to replace one on an inboard engine.
I don't think the one I have is suitable.
Thanks.
keith-pu8 is offline   Reply With Quote
Old 08-12-17, 02:36 PM   #2
ListerHA2
ListerHA2's Avatar
Try this company. Stick 44mm and length into calculator.
http://www.beltingonline.com/flat-endless-belts-13049
ListerHA2 is offline   Reply With Quote
Old 08-12-17, 02:55 PM   #3
Interesting looking little unit - what is it?
Old 08-12-17, 03:43 PM   #4
ListerHA2
ListerHA2's Avatar
Appears to say "MADE IN ENGLAND" on the alloy bit?
Old 08-12-17, 05:43 PM   #5
keith-pu8
keith-pu8's Avatar
It's an early 50's, 1951-53, Anzani inboard motor, based on the Anzani super single.
I have some info on it, the original Anzani Dinghy motor, as it was called, had the exhaust below the head, this one is a year or so later, still never seen another, or anything like it.
With forward neutral reverse.
Old 08-12-17, 05:51 PM   #6
Thanks, I've certainly never seen the like before either.
Old 08-12-17, 07:31 PM   #7
thanks for the useful link
Old 08-12-17, 11:53 PM   #8
keith-pu8
keith-pu8's Avatar
Thanks, that looks very much what I need, much appreciated.
Old 09-12-17, 12:13 AM   #9
ListerHA2
ListerHA2's Avatar
Suggest you inform the company how much HP the belt needs to transmit and at what RPM, and also that the bearings are 'overhung'.
Modern fixed centre belt tensions can be quite hard on older kit.
