Old 15-05-17, 08:46 AM   #1
yorkshire tink
Default Recycling saw blades.
I've just rescued half a dozen tungsten carbide blades off our steel drop saw from the bin at work and thought I might be able to do something with them.
Was thinking I might be able to make some scrapers or wood chisels ?
Any ideas how to cut them ? Would a regular cutting disc work ?
Any other ideas of anything else I can use them for would be appreciated.
yorkshire tink is offline   Reply With Quote
Old 15-05-17, 10:01 AM   #2
I assume they are tungsten carbide tipped blades? The blade material is unhardened and of little use. There is a good reason your company put them in the bin - put them back where they belong!
Old 15-05-17, 11:40 AM   #3
If they are tipped blades a saw doctor will be able to braze new tips onto each tooth, if your company is like mine it's less hassle to buy a new blade than repair the old one.
Old 15-09-17, 06:21 PM   #4
I was given some old blades and, having ground off the teeth, they make excellent scrapers
Old 15-09-17, 08:15 PM   #5
Or you could drive an automated saw sharpener from your engine?
Welland17SER175 by Robert Starr, on Flickr
Old 15-09-17, 08:20 PM   #6
eddie78
Thats a unfortunate middle name
eddie78 is offline   Reply With Quote
Old 15-09-17, 09:08 PM   #7
Some of those saw sharpeners are quite hypnotic to watch.
nickh is online now   Reply With Quote
Old 24-11-17, 09:55 PM   #8
110samec
110samec's Avatar
They make handy scrapers
Petter PAZ1, Suffolk 75G14, Ruggerini RF120 + fire pump,1976 Series 3 Land Rover
110samec is offline   Reply With Quote
