Go Back   UK Stationary Engine Forum > Main Engine Section > Engine-Specific Forum Sections > Lister D & F
Old 18-09-17, 12:47 PM   #1
Solsteam
Default Re-Badged Lister D
Can anyone tell me if there is such a thing as a rebadged Lister D. I have an as yet unidentified crankcase. It is a 23D spec; I assume these are the only ones with oil filler one side with capability off undoing plate on other side to swap over. Yet there is a rivetted tag on the block with date as 8-3-40 yet it is not a 26D crankcase. Can you let me know what's going on here?
Solsteam is offline   Reply With Quote
Old 18-09-17, 12:57 PM   #2
What does the tag actually say, Lister's used to take engines and refurbished them and resell with a refurbished date tag.
I know of no rebadged engines.
Old 18-09-17, 02:46 PM   #3
Solsteam
Hi Martin, all the tag says is 8-3-40 nothing else. Seems a short time to refurbish an engine but does explain the date on a spec 23. Thankyou
Old 18-09-17, 02:58 PM   #4
Solsteam
here is photo of tag
Old 18-09-17, 04:19 PM   #5
cranium
cranium's Avatar
It looks like a casting number in the pattern to me, rather than a 'tag'. The engine could have been rebuilt at works into a crankcase which was manufactured and machined anytime after that date.
E
cranium is offline   Reply With Quote
Old 18-09-17, 04:23 PM   #6
My spec 18 D has the removeable plate as well, infact my filler is on the opposite side to normal.
Old 18-09-17, 05:20 PM   #7
eddie78
my 23 and 26 both have the removeable plate but there some slight differences between the crank case such as the oil drain is a different height
I you need any pics etc.... more than happy to help
eddie78 is offline   Reply With Quote
Old 18-09-17, 05:38 PM   #8
Solsteam
E
Thank you cranium
Old 18-09-17, 05:42 PM   #9
Solsteam
Thank you Eddie that makes sense then. Crankcase could well be a 26 even though a dead spit to a 23. If it is 26 then I have a good idea of its identity although the spec will remain unknown at moment.
