Go Back   UK Stationary Engine Forum > Main Engine Section > Engine-Specific Forum Sections > Lister A & B
Old 08-06-17, 08:11 PM   #1
Default Unusual Lister A
Hi,
I currently have a Lister A engine fitted with B274 flywheels (22" by 2.5"). DWE's Lister A/B book and Peter's website both list this flywheel option as fitted to a few A types, but no Spec numbers mentioned. The Spec plate is missing and there are no numbers stamped in the flywheel faces. Anyone know anything about this unusual fitting ?
Old 09-06-17, 08:09 AM   #2
slb10420seac
slb10420seac's Avatar
I can't really help but is the engine number stamped on the end of the crank?
slb10420seac is offline   Reply With Quote
Old 22-06-17, 08:52 PM   #3
allan grieve
Default lister junior
is it tank or hopper cooled have you a photo?
Allan
allan grieve is offline   Reply With Quote
Old 23-06-17, 05:41 PM   #4
Old 23-06-17, 05:58 PM   #5
It is mentioned in the Changed Number List:
Flywheel B274 22" X 2-1/2", (Used on a few engines only) Replace by 2off X Part 2/474.
No Spec No's, nothing.
Quite a rare engine.
Old 23-06-17, 06:23 PM   #6
Thanks for your helpful suggestion.
The governor side crank has 321 stamped in the end. I think this is the part number. Also the flywheel on this side has SPARK stamped into the face. According to DWE this was phased out in the mid 1930s.
The fuel pump side crank has 36431 stamped in the end. If this was correct it would make it a very early engine, which it clearly is not (see photo above). So let's assume that it is missing the 2 from in front of this number, so we have 236431 which would date it approximately 1935/6. Spec still unknown though...
Old 23-06-17, 08:05 PM   #7
Brother has one with the skinny flywheels and his one has the square skid mounted tank. No idea of the spec tho. Sorry.
Old 24-06-17, 10:59 AM   #8
'A' Lister
'A' Lister's Avatar
A nice looking engine.
Jules-
1940 Lister D, 1940 Lister A, 1943 Lister D, Bentall Mk J corn mill, Bamford K1 Rapid Mill, Lister H2 Pump, 12v CAV dynamo.
'A' Lister is offline   Reply With Quote
Old 24-06-17, 06:31 PM   #9
OK, been in contact with Doreen Edgington over the numbers discussed above.
Engine No 36431 is 2 hp A13H dated 2-2-1924, and as I stated it is clearly not this as it has no early features at all.
Engine No 236431 is a 9 hp Spec 104LH dated 15-9-1936, it's also clearly not an L type either . In his book David mentioned that some Lister A engines were duplicate numbered with Lister L engines due to clerical errors, maybe that's what happened here ?
So we've reached a bit of an impasse on this unless anyone has any bright ideas.
