UK Stationary Engine Forum (http://www.stationary-engine.net/forum/index.php)
-   Lister D & F (http://www.stationary-engine.net/forum/forumdisplay.php?f=187)
-   -   Rings (http://www.stationary-engine.net/forum/showthread.php?t=42175)
micro 23-05-16 07:56 PM
Rings
hi
can anyone tell me when the thickness of the piston rings changed I have a 1939 D that needs rings
the piston looks to be a good fit
mike
danthetangye 23-05-16 08:26 PM
Originally Posted by micro (Post 369190)
hi
mike
Best thing is to take it out and measure what you have got. Needs to come out anyway if you want to change the rings. It may not be the original piston so difficult to tell. Gives you chance to measure the piston and bore properly as well to check for wear, it may be already bored oversize.
micro 26-05-16 02:42 PM
stripped down the d
40+thou Gap on rings ,white metal on big end bearing shot , Think I bought a pup
I need a conrod with the oil dipper and +020 rings for the piston which feel ok in the bore
its +020 stamped on the piston
and I think it will live again
mike:embarrassed::oops:
:mega_shock:
nickh 26-05-16 03:02 PM
Originally Posted by micro (Post 369328)
(snip) Think I bought a pup
No, you bought an old engine which has the sort of wear you would expect from a long and tough working life. :whistle:
The big end is a replaceable bush btw and they crop up on ebay from time to time - I'm not getting into the debate as to whether the modern unlined bronze replacements are any good!
Windrush 26-05-16 04:19 PM
Rings on ebay, cheap enough as well.
http://www.ebay.co.uk/itm/LISTER-D-D...F7HnBFFpgG4SRg
micro 26-05-16 04:19 PM
yes I agree bush ordered . Broke off the dipper trying to remove it it had been centre popped in not having a good day
some days things don't go to plan
well Hey Ho I'm not beaten yet
mike
:oops:
micro 26-05-16 04:27 PM
thanks Windrush
followed your link cant make up my mind wether to rebore to +030 or take a chance on +020 seems to me there is very little play in the piston when its in the barrel the old rings don't seem right to have that much play
mike
nickh 26-05-16 07:52 PM
Originally Posted by micro (Post 369333)
(snip) Broke off the dipper trying to remove it
The only D I have ever owned had had the dipper replaced with a bolt filed to shape.
micro 09-06-16 07:49 PM
rings
Hi
Further update
I had the bore measured today +0.26, Is this too much for a new set of rings or shall have the block rebored Oh !and I found one of the valve caps in the sump
mike
Hornet 6 09-06-16 08:00 PM
Originally Posted by micro (Post 370109)
Hi
Further update
mike
+ .026" is most of the way to + .30" which is where i'd want it bored.
Neil. :)
