Old Today, 10:05 AM   #581
Originally Posted by Paul_Sterling View Post
Neil,
<snip>The losses become huge around the boiling point, and all that is energy being sucked out of your engines cooling jacket. as long as the cylinder head is not exposed, your engine can boil water merrily.
Boiling water it does really well, not sure how the head could be uncovered though ?
Its tank cooled, water is pumped from bottom of tank into the bottom of the cylinder, the return just flows back from top of head to the barrel again, at about 5 or 6 gallons a minute
Old Today, 10:34 AM   #582
Paul_Sterling
Paul_Sterling's Avatar
The head will only be uncovered if that water boils away until the level drops to that point (or in your case, till when the pump can't pump any more water), that is all I was indicating. As long as the head has a covering of water, you can let them boil happily. These are (mostly) cast iron piston engines, they can run pretty hot with no problems.
On a side subject, Ruston specified some pretty low continuous operating temperatures for the Ruston HR series diesels, in fact for my 1HR, they were specifying only 60 degrees, but in reality, a diesel is far more efficient, and far less likely to bore glaze if the water temperature is in the 90's, they just need more careful monitoring to ensure the level does not drop, which is where the risk of exposed engine surfaces creeps in.
Paul Sterling A Stationary Engine Obsessionist
Paul_Sterling is offline   Reply With Quote
Old Today, 02:06 PM   #583
Unfortunately the 'cast iron' piston I ordered from Stuart Turner Bits, was delivered to the local machine shop with the barrel for boring by my son, it wasn't until several months later when I went to collect the bored cylinder I found the new old stock iron piston was actually second hand aluminium
I spent a long time trying to find an iron +.030 piston with no luck, that is why I decided on using a pumped system, so far no issues, and the worry ov the high temps is probably more of a problem to me, than it is to the engine. Lol
Time will tell, but it's been rallied the last two weekend in hot weather and run like a clock, this weekend its getting a two day event, if it doesn't work out at least I'll have a game fair to look around
Old Today, 02:39 PM   #584
Paul_Sterling
It'll be absolutely fine.
Old Today, 03:03 PM   #585
Perhaps I just like to worry
It's done a two day bash before with a bigger load so I'm sure it will survive another
