Go Back   UK Stationary Engine Forum > General Transport Section > Towing & Trailers
Old 22-05-18, 05:51 PM   #71
Bridge weight limits are simple enough, if it states '17 tonne GVW limit' then you shouldn't cross it with anything that is plated for carrying more.
Old 22-05-18, 05:55 PM   #72
Having read this thread from the beginning I havent got a bl**dy clue what you are all on about.
Old 22-05-18, 06:03 PM   #73
Lucky for you that you are old enough so it doesn't matter then isn't it....
Old 22-05-18, 06:19 PM   #74
That's a relief Martin, you won't be reporting any of us for being 2 Drachms over the allowance according to line 3, paragraph 8, chapter 29 of regulation 3456-456-567-5678-4567 which we all should know about as it was available for viewing in a basement in Schleswig-Holstein for twenty minutes last Wednesday fortnight.
Old 22-05-18, 06:54 PM   #75
It might matter as I'm restricted to 3.5 ton as I inject Insulin. Knowing my luck they have changed that to.
Old 22-05-18, 11:09 PM   #76
“But the plans were on display…”
“On display? I eventually had to go down to the cellar to find them.”
“That’s the display department.”
“With a flashlight.”
“Ah, well, the lights had probably gone.”
“So had the stairs.”
“But look, you found the notice, didn’t you?”
“Yes,” said Arthur, “yes I did. It was on display in the bottom of a locked filing cabinet stuck in a disused lavatory with a sign on the door saying ‘Beware of the Leopard.”. (Douglas Adams fans will understand)
Old 22-05-18, 11:24 PM   #77
Yep, unashamed plagiarism!
Old 01-06-18, 10:30 PM   #78
Originally Posted by pulsechoes View Post
More converted biscuit tins!!
Not really, I went down and had a look at them today, for a "biscuit tin" it was well made, felt like 4mm or 5mm channel chassis and the buck was 3mm. Paid my deposit...
https://www.ebay.co.uk/itm/NEW-Car-T...19.m1438.l2649
Old 02-06-18, 09:28 AM   #79
Headless
Headless's Avatar
You need to be careful there are some misleading dimensions on that advert.
Side height is shown as 1' 15" and
External Width as 5' 51"
Andy
Visit Internal Fires eBay shop http://stores.ebay.co.uk/Internal-Fi...id=p4340.l2563
Headless is offline   Reply With Quote
Old 02-06-18, 10:33 AM   #80
Had a measure, its been converted to a decimal inch, it's 12.15inches high and 60.5 wide....
